diverter valve
Old Aug 8, 2009 | 05:21 PM
gedas429's Avatar
Exclamation diverter valve
hi,
i have audi a4 2000 1.8t and i have put apr chip. i love it. and then i changer diverter valve. i thought i will get that "swoosh" sound but i guess you have to put blow off valve right? is there are any way to make that "swoosh" sound with diverter valve?
Old Aug 8, 2009 | 06:51 PM
ImTheDevil's Avatar
You'd need a hybrid valve that recirculates some of the air and purges some. Running a full blowoff is not advised - the rich spikes will end up destroying your cats.
Old Aug 9, 2009 | 12:05 AM
gedas429's Avatar
so basically i cant make it to make any noise with diverter valve?
Old Aug 9, 2009 | 12:11 AM
gedas429's Avatar
even though if i would put cold air intake it would still not make that "swoosh" noise right?
Old Aug 9, 2009 | 12:25 AM
kriptonik's Avatar
If you're expecting sound similar to Evos, STi's, or even Toyota Supras - you'd be disappointed. After an intake, it would be more audible but it will not make a BOV sound.
Old Aug 9, 2009 | 01:31 PM
yuriy's Avatar
I have the Forge Splitter and im very satisfied. Even without a cold air intake it was pretty loud.
Edit: and im not even chipped so its around 9 psi.
Old Aug 9, 2009 | 01:41 PM
Mike-2ptzero's Avatar
You will hear more of the BPV because the stock air box is designed to reduce the sound coming back out of the intake.
If you want more sound then get a hybrid valve, it will let you set how much air is sent thru the BOV part of the valve. You can get this type of valve from GFB or Forge.
GFB Hybrid. This one you can not adjust how much goes out each side.
GFB FX Stealth
They even seem to have one now that you can control from the cabin.
Forge Splitter(basically a copy of the GFB)
Connor Schleicher
Nov 8, 2011 07:13 PM
07titanium
B7 Models
Oct 25, 2011 08:11 PM
justinclink1
Aug 30, 2010 11:40 PM
07titanium
B7 Models
Mar 5, 2009 08:29 PM
FtMyersAudiFreak
May 25, 2005 11:35 PM
