drivetrain question
Old Oct 15, 2008 | 07:23 PM
NoChance's Avatar
Default drivetrain question
Is there anyone out there who makes a limited slip for our dif? or even a full spool? Any info would help. And how much poweer can the stock drivetrain handle? (manual tranny)
Old Oct 15, 2008 | 07:54 PM
ghost6303's Avatar
the center part of the diff has several bolts that should be replaced if your looking to go over 350-400hp. but if you do that it can handle an *** load of power. you may torque a half shaft into pieces, but those can be replaced fairly easily.
stasis makes several different differentials for these cars, also you can get an upgraded peloquin (sp?). theres a company that makes limited slip diffs that i cant remember the name of right now, they are out there tho. try searching the forum for peloquin or stasis differential.
Old Oct 15, 2008 | 10:56 PM
Mike-2ptzero's Avatar
I still run 100% stock OEM driveline in my A4 that makes 600whp.
Old Oct 15, 2008 | 11:28 PM
A4speed's Avatar
yeah, your fine stock.
Old Oct 15, 2008 | 11:41 PM
NoChance's Avatar
sweet, thaks. but i'm still going to look into the limited slip just for traction's sake.
Old Oct 16, 2008 | 10:35 AM
Why? A limited slip diff for the rear is around $1200. Not exactly needed for a AWD car like it is needed for a rwd/fwd.
Old Oct 16, 2008 | 07:55 PM
EpicWin's Avatar
Cause when you are under hard cornering in a race, you want the power to go to the outside wheel that's being driven.
There is a market for this LSD unit, meaning there are people who are willing to spend pretty good money for a high quality product.
Old Oct 16, 2008 | 10:30 PM
Ok, just wanted to know if you were going to be using it road racing, because its a expensive mod for a daily driver.
Eurocode and 034 use the LSD's in their cars.
Old Oct 17, 2008 | 09:51 AM
euro_2nr's Avatar
I thought the Stasis was $550 after you return your core?
Old Oct 17, 2008 | 04:31 PM
That is the center diff (tosen) upgrade not a LSD rear/front diff.
ThatRetardedKid
Apr 17, 2012 10:17 PM
judeisnotobscure
Sep 18, 2010 12:48 PM
mlwartman
Mar 9, 2010 08:25 PM
mlwartman
Mar 1, 2010 10:33 AM
conradatlas
May 31, 2008 09:17 PM
