Front wheel bearings
Old Aug 14, 2013 | 04:21 PM
Expplucky's Avatar
Default Front wheel bearings
ive searched cant find a diy for the b5's
anyone know of a good one, i mean i know you gotta get a press and all that but i want to make sure i know what the parts look like before i order them.
Old Aug 16, 2013 | 03:05 PM
jeckel20003's Avatar
There's one on replacing the front control arms. It should help get you where you need to be to get to the front wheel bearings. AudiWorld Tech Articles
Old Aug 16, 2013 | 03:20 PM
bshusted's Avatar
Once you get the upright off of the car, it's not too bad.
1. Press out the old bearing by supporting the upright and pressing on the outer race (find a socket or pipe fitting close enough to the size).
2. Separate the inner race from the hub either using the press and a clamshell or cut the old bearing and beat it off.
3. Press new bearing into the upright (be careful of the orientation of the step in the bearing/hub). Be sure to only press on the outer race of the bearing and not on the seal.
4. Press hub into new bearing. You must support the inner race with an appropriately sized pipe or socket. This is critical and will damage the bearing causing premature failure if you do not support the inner race.
Tapeman
B8 Models
Oct 19, 2014 07:27 PM
jjcrt2
Jul 17, 2009 03:24 PM
fritz
Sep 5, 2007 07:08 PM
patrickm2002
Aug 10, 2007 12:37 PM
fhf3723
Mar 12, 2007 05:28 AM
