New front wheel bearings?
Old Mar 11, 2007 | 08:42 PM
fhf3723's Avatar
Default New front wheel bearings?
Just replaced both half axles on wfes A6Q because the boots split and she ran it until the cv joints ruined. Car was making a noise like a train (thump thump thump?) Worse when the front wheel was turned to the left. After replacing the half axles the noise is still there. Do I need new wheel bearings? How can you check for that, and if I need to replace them how hard is it to press out the old and press in the new? Is it spendy to have a machine shop press? Thanks in advance.
Old Mar 12, 2007 | 05:28 AM
auditech79's Avatar
Default RE: New front wheel bearings?
I doubt the front wheel bearings need to be replaced, if they aren't making noise the faster you go they shouldn't be bad. Take it back to the shop that did the repair and stick it to them saying that there is a noise after the repair was made and be **** about it because they are gonna play hardball but they will buckle sooner or later kinda like my service managerIf you wanna replace the bearings you have to remove the tie rod end, remove the upper links from the steering arm, remove the large 17mm allan from the hub holding the axle in place then remove the hub from the vehicle, it should have a couple of bolts holding it in from the rear. Press it out as any normal bearing and install the new one by pressing it in, but i would have the shop do it for ya.
Tapeman
B8 Models
Oct 19, 2014 07:27 PM
Expplucky
Aug 16, 2013 03:20 PM
jjcrt2
Jul 17, 2009 03:24 PM
fritz
Sep 5, 2007 07:08 PM
patrickm2002
Aug 10, 2007 12:37 PM
