Fuel gauge issue, what now?
Old Jul 12, 2012 | 03:19 PM
DanaB6's Avatar
Default Fuel gauge issue, what now?
My fuel gauge has been acting up (when i fill up on half a tank it shows i have 3/4's of a tank, when i fill up on 20$ it says i have half a tank, and when i fill up on a full tank it says i have less than half a tank), i took out my fuel sending unit and i replaced the wire that usually goes bad (it was pretty corded), and i cleaned the sensor. But i still have the same issue, it didnt change anything. So is the whole fuel sending unit bad and i need to replace the entire thing or could it be something else? The sending unit looked pretty bad honestly, looked like it was burned out, but we tested it and it gave normal readings.
Old Jul 12, 2012 | 07:07 PM
jonbonesjones's Avatar
Moderator
sounds like you might have a short elsewhere. if you did replaced the level sending wire and the connection is good it should be good to go.
Old Jul 12, 2012 | 11:06 PM
z28pete's Avatar
You could test the sender by removing it from the tank. Connect an analog Ohm meter across the leads going to the fuel gauge. Move the float through its range while observing the meter. The Ohm meter indicator should sweep across the dial folowing the movement of the float, there should not be any flat spots or sudden drop outs to infinity or to zero.
Old Jul 12, 2012 | 11:22 PM
DanaB6's Avatar
I did that, the ohm moved when I movoed the sender.but the voltage would sometimes drop when moving up.
Old Jul 13, 2012 | 06:07 AM
ImTheDevil's Avatar
Then either the resistive element is dirty, warped, or damaged, or the wiper is losing contact during the sweep.
Old Jul 13, 2012 | 07:09 AM
Moderator
did you clean it when you took it out? its electrical contacts they get dirty. how good was the solder job?
Torro
Apr 8, 2015 06:46 AM
mnorm757
B7 Models
May 11, 2011 04:00 PM
simon264
Mar 7, 2011 09:29 PM
southcoast
Mar 19, 2007 10:38 PM
malamutt28
Jan 19, 2007 07:36 PM
