Help! ICM Location on '98 a4
Old Aug 3, 2011 | 09:45 AM
truthinengineering's Avatar
Default Help! ICM Location on '98 a4
Hi all,
I am in the midst of trying to diagnose a suspected failed ignition control module on my '98 a4 1.8t. I have seen several posts on this site and others saying that the ICM is located on top of the air box, but it is not there on my particular model. Can someone tell me exactly where to find the ICM on my car?
Old Aug 3, 2011 | 10:20 AM
Totally just found it, boy that was easy...
Old Aug 3, 2011 | 12:12 PM
CCA4's Avatar
Old Aug 3, 2011 | 01:39 PM
MetalMan's Avatar
If you are good with wiring, you can actually remove the ICM and replace all the coil packs with a newer style for ~$160 (I just did), which is about $50-100 less than the cost of a new ICM. You will also get a slightly smoother idle, stronger spark, and slightly smoother acceleration.
This is of course assuming the ICM is bad... I decided to remove mine by doing this conversion before the ICM failed though.
joshf
Oct 28, 2008 10:09 PM
saltwatergold
Dec 17, 2007 01:38 AM
ukaudia6
Dec 11, 2007 03:08 PM
Yeff24
Nov 21, 2007 12:23 AM
audi416
Mar 19, 2006 11:53 PM
