Help a noob
Old Feb 17, 2011 | 02:19 PM
DOC_DEPALMA's Avatar
Default Help a noob
Which is me.
Ok I can't figure out how to get a pic up here from photobook so here's the link. Sorry for the trouble.
http://s349.photobucket.com/albums/q..._5629756_o.jpg
Obviously my engine is out of time, which means I need to pull the heads off again. When I do, how should my valves be positioned, particularly the passenger's side (I believe the driver's side is set right).
I really need to get this done but I'm effin lost. I haven't had my car running in almost a year, if you feel my pain.
Old Feb 17, 2011 | 02:40 PM
JASEA4's Avatar
once you have uploaded into photo bucket there will be a drop down under the pic , copy and paste the img code in the forum , pics are then on the site , simples
Old Feb 17, 2011 | 04:16 PM
Msnickbroderick's Avatar
Actual WIZARD
Ok, this is the 3rd thread with this EXACT same picture, and the "uh idk fix it guys".
We wont tear you apart for bumping your own thread with a question. However we will if you post 90 threads about how your 2.8 isnt in time
For the record, when posting, theres that little yellow box with mountains and a sun above the text box. Click it and past the location of the picture, and it will look like this
[IMG]Http://www.pictureplace.com/blah/IMG_001.jpg[/IMG ] (removing the space)
Old Feb 17, 2011 | 04:28 PM
ImTheDevil's Avatar
If you're going to pull the head to do this, you're playing it safe, and that's good. Trying to rotate the cam sprocket with the head attached might cause the valves to hit the pistons. When you pull the head, all you need to do is get the oval bracket on the cam sprocket level, with the larger of the two holes in it toward the center of the engine, just like the driver side bracket is positioned. See how the oval bracket has the small hole and large hole and the larger one is toward the center of the engine? Just position your cams such that the bracket on the passenger cam sits the same way (in essence, a mirror image). Long as you have it close before you reinstall the head, you can make minor adjustments to it to level the bracket. This will time the cams properly. Then both heads will be set, and if I remember right, your crank is already positioned correctly (notch in the crank pulley aligns with the timing mark on the lower cover). If that's the case - crank is set to the mark, and cams are both set as described - you can put the belt on and tension it, and reassemble the car.
Old Feb 18, 2011 | 10:44 AM
Mike-2ptzero's Avatar
Posting the picture is very simple. Here it is for you.
Old Feb 18, 2011 | 03:27 PM
Thanks alot guys, mostly you Devil. Helpful as always
[ I understand how multiple threads could tend to get annoying, however: imagine looking at the same broken car every (deleted)ing day of your life and just wanting to put a (deleted)ing bullet in your head. ]
Old Feb 18, 2011 | 03:31 PM
Oh yeah, Keegan. I'm pretty sure I get 87 more posts of that same picture before I start to **** people off, at least by your standards. Maybe I'll photoshop them and paint them pretty colors, I can even add faces... this sounds fun.
Old Feb 18, 2011 | 04:23 PM
vgo's Avatar
vgo
what devil said. it should look like this
Old Feb 18, 2011 | 08:48 PM
Actual WIZARD
Oh hell yes! I would love you if you did that
Old Feb 22, 2011 | 06:57 PM
hahaha if only i had the time
phila1776
Dec 12, 2007 12:38 PM
sheatswitch
Dec 6, 2006 09:02 PM
Euroluv
Nov 14, 2006 09:05 PM
TheAudioGuru
Nov 1, 2006 03:35 AM
AdLucem
Mar 9, 2006 04:29 PM
