Help replacing cat. One bolt wont come off.
Old Aug 2, 2008 | 11:07 PM
mel23816's Avatar
Default Help replacing cat. One bolt wont come off.
Does anybody have any experience in replacing a cat on a 99.5 1.8t? I was able to take 2 bolts out from the cat to downpipe. But one wont come off, now the thread is gone. Its the one closest to the engine. Do I have to cut it? Please HELP!
Old Aug 2, 2008 | 11:28 PM
ghost6303's Avatar
i put on a milltek exhaust a few months ago and had to cut out 2 of the bolts between the cat and downpipe with an acetaline torch. you can try drilling or using one of those broken bolt retriever bits but good luck getting a drill in there.
Old Aug 3, 2008 | 11:39 AM
The Bishop's Avatar
It's a pain but you can unhook the downpipe from the rest of the exhaust and then pull the downpipe out the top to get at the bolt. It's a pain though.
Old Aug 3, 2008 | 12:33 PM
Siena's Avatar
The angle grinder's a mans best friend...
Old Aug 3, 2008 | 01:39 PM
SlimChriz's Avatar
Sawsall + Metal blade = Done .....you have to replace the studs anywho.
Old Aug 3, 2008 | 03:51 PM
98 a4's Avatar
Thats exactly how i got mine out...its such a pain in the a$$ to get the cat out. but if you do use the sawsall just make sure that you carefull of the fuel line because i accidently cut mine...oppps haha.
Old Aug 3, 2008 | 04:10 PM
onepoint8tee's Avatar
Are you getting at the bolts/nuts from the top or bottom? The bolts are welded to the cat on top and you gotta get the nuts off from the bottom with a long extension. If you got them out from the top, they had to have broke off.
Old Aug 3, 2008 | 08:48 PM
compmanben's Avatar
you could try a dremel!
savantv
Jun 14, 2012 10:19 AM
moneyfresh
Jun 10, 2012 09:41 AM
Dudek12
Mar 11, 2005 11:30 PM
