HID Relay Install Kit (Ballast Location)
Old Dec 9, 2013 | 11:32 AM
AudiTurbo's Avatar
Default HID Relay Install Kit (Ballast Location)
So, I have been having problems with my HID kit since install. One light has always been a little bit dimmer (changed the light bulb several times), when I flip the headlights on the radio kicks off and now I'm getting flickering of one headlight. I'm just using the splicing I did when I changes from 2 piece headlights to one. My question is if I do the relay kit, where should I put the ballast since it's running straight to the battery? Will this solve my problem?
Thanks
Old Dec 16, 2013 | 08:12 AM
AudiTurbo's Avatar
So, I finally got the relay setup and it is working fine, but I'm still having a problem with one headlight being brighter and one being blue. I has swapped bulbs, new ballast and everything else, but nothing works.
Any ideas?
Old Dec 17, 2013 | 02:55 AM
Skythe's Avatar
If you've swapped bulbs and ballasts and are still having the same issue, it could be your projectors or how they're aimed. E-Codes? Or OEM?
I had something a little similar. Coincidentally, I had to install a relay kit as well.
Old Dec 17, 2013 | 09:41 AM
AudiTurbo's Avatar
OEM I believe
It still doesn't make sine with the color difference.
Also, you have a good DIY for leveling headlights? I see the screw spinning but it looks like it doesn't work
thanks
MY06STi
Dec 14, 2011 06:23 PM
megailko
B7 Models
Oct 2, 2011 09:33 PM
josh_easlon
Feb 24, 2010 04:37 PM
Megathunderultrazord
Dec 31, 2006 11:15 AM
muscle750
Oct 17, 2006 06:31 PM
