hoping someone more knowledgeable then me can help me haha
Old Nov 23, 2010 | 09:44 PM
twilliams83's Avatar
ok so i did a leak check and i have none (i used the tennis ball method), i read on another forum that it could be the n75 valve, so i went ahead and checked that, i read to check it to disconnect the top hose and to drive it and see if it boosted up, it did so does this mean i have a bad n75?
Old Nov 26, 2010 | 07:52 PM
So i cleaned the maf sensor with the cleaner from auto zone, scanned it i got the lame code as last time p0102 we erased it and this time it seems like its gunna stay off
But i think im still in limp as im only boosting 4 psi occassionally it will touch 5 psi if im lucky. Does any one got any ideas?
Old Nov 26, 2010 | 08:12 PM
Tweaked's Avatar
Start by checking for leaks in the boost gauge lines just to eliminate a tail-chasing situation. If it checks out ok, check all the lines to your N75. YTou should have a DTC stored if it's in limp.
Old Nov 26, 2010 | 09:32 PM
ive checked the boost line multiple times so im 98% sure its not that, my cel came back on
but what is a DTC?
Old Nov 26, 2010 | 09:34 PM
i also checked the n75 today and put new hose clamps on it and checked lines
whats the filter above the n75?
Old Nov 26, 2010 | 11:16 PM
Tweaked's Avatar
DTC means diagnostic trouble code. What code is stored?
Old Nov 26, 2010 | 11:24 PM
oh sorry
thanks for the help
the code that i keep getting is P0102
Old Nov 26, 2010 | 11:35 PM
  #18
02A6Beau's Avatar
Not to keep beating the dead horse BUT
P0102 is a MAF sensor code. Problems with the MAF sensor will cause the lack of power you are describing. Its either the MAF sensor or a wiring/connection problem to the MAF sensor.
Old Nov 26, 2010 | 11:41 PM
  #19
Tweaked's Avatar
So its the same code again. I think you're going to need a MAF at this point if cleaning the MAF, TB and TB adapt hasn't worked. You've eliminated boost leaks and vacuum leaks, so the code points to MAF or wiring.
Old Nov 27, 2010 | 03:04 AM
  #20
Alright well i guess tommorow ill check the wiring then if thats not it ill bite the bullet and get a new maf sensor and hope that fixes the problem. Thanks for the help
Guys
james0013
Apr 19, 2009 10:06 PM
Dynamikz
Jun 24, 2007 10:12 AM
pyrotechnique
Sep 19, 2006 09:05 PM
a4autocrossr
Jul 18, 2006 04:42 PM
