How to increase boost???
Old Jun 19, 2012 | 08:05 PM
ImTheDevil's Avatar
Might be tough to get a fast-spooling turbo that hits hard at 20psi, in the price range you quote. I'd say after driving dmaxn's APR stage 3 car with GT28RS last year, that I'd go with that. Nasty turbo, makes very strong power, and spools fast. If you want to spin 800"RPM, you're going to need to build the head and run bigger injectors (which the RS would necessitate anyway).
Old Jun 20, 2012 | 10:42 AM
J_PEZ's Avatar
I def plan on running bigger injectors and building the head, I have ran precision turbos and super 60's before and hit 25lbs nicely. I just would like to see whats the better turbo for the a4 since I have only been playing with them for a few months. I was thinking about a gt30? I was trying to keep the turbo price down, but im putting aserious limit at $1200. Anymore advice?
Old Jun 20, 2012 | 10:48 AM
ImTheDevil's Avatar
Knowing your power goals would help. A 1.8T isn't going to spool a GT30 very quickly at all. The GTRS or a 71r will spool quite a bit faster and make really good power.
Old Jun 20, 2012 | 10:52 AM
CCA4's Avatar
Yeah if you want to run a GT30 series turbo or larger you're also going to want to go 2.0L at least. You can run a 2.0L crankshaft, H-beam rods and AEB/IE pistons. Make sure you read up on doing a bottom end build before you start buying ****. You're going to have to get your intermediate shaft clearanced in order to run a stroker kit.
Old Jun 20, 2012 | 10:59 AM
ImTheDevil's Avatar
At this point you'd do well to talk to Mike Hood at Ringer Racing. He'll set you straight.
Old Jun 20, 2012 | 11:20 AM
J_PEZ's Avatar
thx guys. Alright so I got the gt30 idea out the window. Im going to start inquiring with my connects about a Gt28... Also I def like the 2.0 stroker kit. Anyone on here done that succesfully so I can ask for questions? I have only ordered a HKS BOV, Greddy Lg front mount, Turbonetics W/G, arp head studs and a couple nick nacks. Im def. at a good point in my build for advice before I order anyparts and that 2.0 set up has really got my ears open!
Old Jun 20, 2012 | 11:25 AM
ImTheDevil's Avatar
Talk to FASTER. He's running a 2.0 BAT setup.
Old Jun 20, 2012 | 12:57 PM
  #18
jonbonesjones's Avatar
Moderator
just need new pistons 83 or 86mm bore (i forget which one) 144/20 rods, 2.0 FSI crank. and a few other things i haven't gotten to yet.
Old Jun 21, 2012 | 09:47 AM
  #19
J_PEZ's Avatar
Im going to run aftermarket rods so I just need to know what engine and what engine for pistons and exact diameter, but ill try to look up "faster"
rowyourown
B7 Models
Jan 20, 2010 09:43 PM
JaMeS_AudiA4
Jun 30, 2008 01:25 PM
neur0tic
May 8, 2007 01:54 PM
azaky
Dec 23, 2006 02:03 AM
