How to install and aftermarket radio without a wiring harness
Ground=Brown
12v Constant=Red/Blue
Illumination=Grey/Blue
12v Switched=Black with small red stripe
This was a great write-up, I came across it when trying to install an aftermarket head unit in my 2001 A6 with the on-Bose system like yours. I purchased a supposedly complete kit off of ebay with the faceplate and all adapters. Everything was great, except for the antenna adapter, which I could not figure out. Your link shows what I believe is the correct one for my system, but where does the blue wire get connected? Also, there is another smaller lead that connected to the back of the stock radio that is wrapped with the stock antenna lead, what is this, the power for the amplified antenna? It looks like a smaller diameter antenna lead with a similar but much smaller connection, I have photos if you need to see them. Hope you still subscribe to the forum - thanks!
With the stock symphony there's a couple cm of clearance at the very top, but tons everywhere else. It would be safe to assume an average double din radio would fit no problem.
I'm onboard with spending the extra cash for a wiring harness. The last 4 cars including my Audi were only ten bucks on Amazon and Ebay! Though I've never used the option it's nice to have it open if you ever want to put the stock stereo back in if you are reselling the car. I seem to always be letting my stereos go with them lately. Especially since new bluetooths are so cheap and they always seem to impress potential buyers. I guess either way is good if you want to take the extra time to wire it in direct and save ten bucks or you just can't wait for the part to be shipped...
There was no wiring harness to speak of in the car. Just bare wires. I'm at least the 3rd owner. 1st owner had some massive stereo in it, and last owner wasn't willing to pay the extra for it.
A "Pioneer super tuner 3" was in here when i got it, but it didn't function anymore. Hardwired it all, and used heat shrink tubing on all connex. GTG!
Your best bet (and easiest way of doing it) would be to buy the wiring harness and find out which wires on the harness correspond to the cars wiring. Make sure you test all 12V wiring for power, test the ground and test the remote wire (for the amp). If you don't damage the aftermarket harness, you should be able to return it when you're done.
G/L
G/L
