How should CCT respond when cranking by hand? Answer ASAP!
Old Sep 24, 2011 | 06:36 PM
strokestroke's Avatar
Default How should CCT respond when cranking by hand? Answer ASAP!
I'm about to fire up my 2.8 after a complete head rebuild. The timing is dead on when I rotate the engine by hand, no contact between pistons and valves.
The cam chain tensioners on both sides tighten, then drop fairly drastically. Up, then down, etc. Shouldn't the chain stay tight once the oil gets into the tensioner?
thanks
Old Sep 24, 2011 | 07:19 PM
ImTheDevil's Avatar
Not sure about oN once pressure is up (never idled an engine with the VC removed) but your CCT is acting as it should now.
Old Sep 24, 2011 | 09:56 PM
Thanks man.
I decided to go for it, bloody thing fired up first crack! A bit of ticking and then it went away within a few seconds. Hopefully all is as it should be, I've been on and off with this thing for months ever since the timing skipped and destroyed a bunch of valves!
On another note, I've never had such a big box of leftover bits after working on a car. . .
Ryanwillbuyit
Sep 22, 2011 08:52 AM
OffshoreGuru
B7 Models
Jul 6, 2008 12:10 PM
awol
Dec 21, 2007 11:10 AM
joelml
Jan 21, 2007 12:22 AM
garciajd
Aug 9, 2006 01:21 PM
