I guess im running too rich??
So my check engine light came on today and went to get the codes read:
Rich air/fuel ratio
Air lead near rear h02
faulty fuel control
Please help on whats going wrong and what I need to do to fix this?
THANKS!
Rich air/fuel ratio
faulty fuel control
THANKS!
16806
P0422
Main Catalyst,Bank1 Below Threshold
That means you have a bad cat converter mate. It happens. You can still check your fuel trims on data block 32 via the vag com, but if thats your only code its probably just a bad cat caused from previous misfires. I would check your misfire counter (data block 16) and see if there are a lot of them. However having a plugged cat can cause misfires.....
Nice wheels by the way.
P0422
