I guess im running too rich??
Old May 16, 2010 | 10:40 PM
slimty360's Avatar
Default I guess im running too rich??
So my check engine light came on today and went to get the codes read:
Rich air/fuel ratio
Air lead near rear h02
faulty fuel control
Please help on whats going wrong and what I need to do to fix this?
THANKS!
Old May 17, 2010 | 10:34 AM
Mike-2ptzero's Avatar
Most likely a bad 02 sensor or bad maf. You need to get the actual code numbers.
Old May 17, 2010 | 07:52 PM
slimty360's Avatar
Code: p0422
Old May 17, 2010 | 08:18 PM
auditech79's Avatar
P0422
Main Catalyst,Bank1 Below Threshold
That means you have a bad cat converter mate. It happens. You can still check your fuel trims on data block 32 via the vag com, but if thats your only code its probably just a bad cat caused from previous misfires. I would check your misfire counter (data block 16) and see if there are a lot of them. However having a plugged cat can cause misfires.....
Nice wheels by the way.
Old May 18, 2010 | 10:42 PM
slimty360's Avatar
Thanks for all the help! I appreciate it. So would you suggest on getting an oem cat, or strait pipe it instead?
Old May 18, 2010 | 11:03 PM
auditech79's Avatar
You can also get an HFC (high flow cat) which is much cheaper than the dealers $600 price tag, and you won't have to deal with the check engine light.
Old May 22, 2010 | 02:55 PM
JETSPEED333's Avatar
SoCal Crew Member
i got mine from ebay...high flow cat.... $150
Andrew149
Aug 28, 2009 06:19 PM
mandito1980
Sep 3, 2008 10:59 PM
incrementalg
Mar 23, 2008 08:02 PM
ooantipostoo
Sep 10, 2007 01:19 PM
oziaudi
Jul 3, 2006 12:08 PM
