Left lights brighter than right?
Hey guys,
So it seems like my left lights (headlights and fogs) are brighter than both my right lights... The funny part is that I just changed my right fog a few days ago but the left fog, along with left headlight, seem brighter...
Any ideas?
Any ideas?
Could be different bulbs or different temperatures (color) of the bulb cause them to appear brighter or darker. You could try cleaning connections for better flow of electricity, although I doubht it would help. I would try getting the exact same bulbs for the headlights and fog lights and see if they are then the same.
Agreed with all of the above. Also, look in the headlight wiring bundle that plugs into the headlight housing. The brown wire is the ground. Get a couple of wiretaps, clamp onto the brown wire on each side, and run a wire from the taps to the chassis. This will "refresh" the grounds for each harness and may equalize the current flow, which can equalize the output of the lights.
If the issue is corrosion (and degraded conductivity) of the ground points, this should help. I even got some braided cable and made a ground web from the negative battery terminal to several pints on the engine, body, and ABS controller to refresh it all as a whole. If your grounds are corroding (as they typically do) you can help the car as a whole this way.
