Low Vacuum like -10psi Idle
Old Aug 3, 2009 | 03:55 PM
neoneddy's Avatar
Default Low Vacuum like -10psi Idle
I'm wondering if this is normal.. this is a 1.8t 1999 A4, I had a 99.5 A4 a few years ago, and it pulled -20 psi at idle, wondering what's up or if this is normal?
I have an APR chip as well, Also is this normal?
Old Aug 3, 2009 | 05:19 PM
Mike-2ptzero's Avatar
most likely caused by low compression or you have a nice size leak at the intake manifold.
Old Aug 3, 2009 | 05:34 PM
2fast4u66's Avatar
Prob a leak (hopefully), do a boost leak test and maybe even try a different gauge to confirm your vacuum pressure.
Old Aug 3, 2009 | 08:02 PM
compmanben's Avatar
hey welcome to the forums, we're always happy to have new members. just so you know, when you get to negatives, the measure for pressure is either inches or millimeters of mercury instead of psi.
Old Aug 3, 2009 | 09:06 PM
ghost6303's Avatar
around -20 to -25 is normal for a stock car. -10 is most likely a big leak somewhere. check your vac lines, especially under the intake mani.
kidhanny
Mar 27, 2012 07:42 PM
swm5126
May 1, 2011 12:39 PM
a4intec
Mar 18, 2011 11:22 AM
theother1wstolen
Aug 21, 2009 07:26 AM
kextyn
Apr 3, 2006 04:23 PM
