lug bolt help
Old May 16, 2008 | 01:06 AM
aledelic42's Avatar
Default RE: lug bolt help
i see.. thats a little more than i want to spend but ill think about it
thanks
Old May 16, 2008 | 10:54 AM
S_R_N83's Avatar
Yeah, thats why its nice to buy from a place that will give you the wheel bolts, and hub rings with your wheels. Its a PITA to get everything separate sometimes.
Old May 17, 2008 | 10:34 PM
aledelic42's Avatar
is there something i should look for in hubcentric rings? like if i just search for a4 hubcentric rings on ebay should whatever comes up work?
http://cgi.ebay.com/ebaymotors/HUB-C...spagenameZWDVW
i would buy that if its fine
thanks for the help
Old May 17, 2008 | 11:20 PM
S_R_N83's Avatar
ORIGINAL: aledelic42
thanks for the help
The correct size is 57.06mm. The ones I have on my car are 57.00mm which is a 0.06mm differenceand they work fine.
Those are 57.10mm which would be a 0.04mm difference. I THINK you will be OK with those.
Old May 18, 2008 | 08:31 PM
aledelic42's Avatar
is the 57.1mm the diameter of the ring? sorry i dont know like anything about this kinda stuff...
if i buy that set how much longer lug bolts should i get?
Old May 18, 2008 | 08:52 PM
S_R_N83's Avatar
Those will work, but you'll still need to get the correct wheel bolt for that wheel.
Old May 18, 2008 | 09:21 PM
aledelic42's Avatar
how can i find out what size bolts to get for the wheels+hubcentric rings
tomhub389
Jul 22, 2010 08:20 PM
AudiFast
Aug 21, 2006 05:18 PM
IWantAnA4
Feb 13, 2005 08:34 PM
