Bolt!
Old Aug 20, 2006 | 04:13 PM
AudiFast's Avatar
Default Bolt!
Anybody have any ideas for getting this bolt out? http://www.audiworld.com/tech/pics/wheel28-front1.jpg
Old Aug 21, 2006 | 12:06 PM
DevilS4's Avatar
Default RE: Bolt!
Leave the nut on a couple threads so there is still a gap, hit it with a hard rubber mallet.
Old Aug 21, 2006 | 03:10 PM
2k S4's Avatar
Default RE: Bolt!
Put some PB blaster on there, you can also put a small pry bar in the openings to help the bolt out.
You will have to tap it with a hammer, the top arms will NOT come out until the bolt does.
Don't worry about the upright, it's really tough and can take it. You should also not reuse any of the bolts.
Old Aug 21, 2006 | 03:27 PM
Coop's Avatar
Default RE: Bolt!
Those may work great if your not from NY or other salt states. From experiance (passats) , what ive had to do is break out the air hammer. use a chissel bit and spread the split collar slightly, then use a combination of heat and penetrating oil (its gona be real smokey). you can either pound on it with a hammer or use a punch bit in the air hammer to knock it out. replace the bolt, always replace this bolt.
Old Aug 21, 2006 | 05:18 PM
AudiFast's Avatar
Default RE: Bolt!
Yeah i have tried beating on it to death and its comin out, thats why i was wondering if someone had any other ideas. i had 2 take the whole hub out to do the suspension. i got it on but the bolt is still in there with no bolt and a mest up end on it. i think im going to have 2 take it to somebody to get it replaced.
bluev8
May 17, 2011 09:44 PM
tomhub389
Jul 22, 2010 08:20 PM
IWantAnA4
Feb 13, 2005 08:34 PM
