Motor swap question
Old Jan 21, 2011 | 11:41 AM
Mike-2ptzero's Avatar
Actually he could go with a AMB out of the B6 1.8t which is basically the same block/head his 01 has. Audi put the 06A in his 01 as a test bed for the B6 1.8t.
Old Jan 21, 2011 | 02:06 PM
Iniquite's Avatar
Originally Posted by cincyTT
The AWM is the only bolt in place setup. A AWW, AWP, and BEA will work but you have to swap the oil pan and pickup since they are different from the transverse to longitude. You can get other 1.8t's but you need to swap the non-vvt chain tensioner to a vvt one.
thanks, thats what I was looking for. I can pull the oil pan and pick up from the old motor but can I do that with the cam chain tensioner? The AWM is quite elusive so I will most likely have to go with a different coded motor. I just got this pic from the mechanic. Most likely will have to replace the motor.
Old Jan 21, 2011 | 02:22 PM
Iniquite's Avatar
Im guessing, but dont want to make a $1500 mistake, that the passat motors with the right code will fit. Right? Obviously Ill have to switch out the mounts and manifold.
Old Jan 21, 2011 | 02:49 PM
FASTER's Avatar
Tech Slut
Passats are actually longitudinal, so it would be a direct swap as long as the engine codes are the same.
Old Jan 22, 2011 | 09:09 PM
Iniquite's Avatar
thank for the the info everyone. I found an AWM from an 02 passat, Ive just gotta get my tax refund back before it sells.
scubcub
Jan 17, 2014 01:36 PM
o0hmikee
Oct 24, 2011 10:19 PM
quiklilrex
Oct 22, 2007 10:29 PM
bdub
Dec 21, 2006 03:49 PM
tank8970
Nov 28, 2005 11:47 PM
