My Maintenance Thread
Old May 24, 2010 | 04:34 PM
bradtyler02's Avatar
Default My Maintenance Thread
Well, I have a bit of maintenance to do when I finally make it home, and I was hoping for some advise as far as my plans, and how I should adjust them to maximize the bang for my buck.
To start, I'm sure it's time for me to do a TB, and I'm pretty sure Blauparts has the most complete kit available, and with the ability to rent the right tools for the job, I think that's an open a shut case for them. This will be a first for me, and I must admit, I'm a little nervous, but what's the worst that could happen?
From there, I think I need to change out my control arm bushings. My car squeeks going over bumps, while turning slow like into a parking spot, even just getting in and out of the car. The arms themselves look good, so I figured I could save some cash by swapping out the bushings. Again Blauparts has what looks to be a pretty complete kit here:
http://www.blauparts.com/proddetail....od=MA21032%2DA
The question here is, am I going to need any special tools, and how difficult will this job be?
Next, I need a new passenger side outer CV joint.
http://www.blauparts.com/proddetail....od=F4A1018%2DB
I'm thinking, if I'm doing one, I might as well do the other just to be on the safe side.
So, I figured, since I'm in there, ripping everything apart for my CA's and CV joints, why not do the wheel bearings. This part makes me a little nervous as well. I'm a pretty basic skilled guy when it comes to mechanics, brakes, oil change, stuff like that. I know if I mess this up, I'm royally screwed. But, again, why not face the challenge head on?
http://www.blauparts.com/proddetail....od=F7W1005%2DA
Again, what kind of special tools might I need for this job?
So, all this should get me started and keep me busy for awhile. Is there anything else I should consider working on now before it fails and causes me more headaches in the long run?
Thanks in advance for any advise, suggestions, or tips you may have...
ludikraut
Mar 11, 2023 11:02 PM
myxyzxo
Mar 22, 2008 11:00 PM
xerexb
Oct 22, 2006 03:44 PM
coma
Oct 8, 2006 07:22 PM
mst630
Dec 30, 2005 04:58 PM
