Need help with fixing coolant and abs light
Old Apr 5, 2009 | 08:25 PM
georger's Avatar
Default Need help with fixing coolant and abs light
Recently my cars coolant light has been bliking. Car does not run hot and coolant is filled to the top, should i just replace sensor and if so how do i do it? Same with my abs light, the abs light is solid though and the break light flases. Used a vag com and it said bad sensor rear abs, should i just replace sensor if so how do i do it?
Old Apr 6, 2009 | 01:28 AM
StubbyVroman's Avatar
The brake sensors are easy to replace, you should be able to just take off the wheel and tire assembly, and the abs sensor should be located below the caliper assembly towards the inside of the brake assembly near the bottom, it just slides in and out, its really easy. The coolant sensor, Im still working on with my own 99.5 A4 2.8. Im not really sure, because im leaking fluids somewhere, I've just been to lazy to locate the leak. Filling it back up to max fill wont reset the sensor though. If you find any info out let me know too, im still searching.
Old Apr 6, 2009 | 02:06 PM
teamdaraptor's Avatar
on my 99 1.8, the coolant sensor is directly behind the engine block itself, somewhere near the middle. As far as I know, its just a plug and play kinda situation. It's a sensor, so I don't know what else you could really do with it lol. My coolant light went away, but I don't have a reading on the coolant guage, so I'm assuming there's a problem with it. I would suggest searching around on the forums here or on audizine. You're bound to find an answer.
Stephenwhite990
Jul 3, 2013 02:25 PM
Dragonfly150
Feb 26, 2012 09:11 PM
Ph3N0m
Oct 21, 2008 12:58 PM
shinnny
Feb 27, 2006 01:53 AM
