NEW B5!!! troubles plz help!!
Old Feb 21, 2008 | 11:08 PM
euro_2nr's Avatar
Default NEW B5!!! troubles plz help!!
Okay well I haven't been on for a while since I've been busy buying a new Audi. Got an opportunity and I purchased a 2001.5 A4 1.8t last saturday. Love the car. Runs great with 60k miles. My other car is the 2001 A6 2.7t so im new to the AMB set up or whatever the 1.8t is. So tonight a friend and I threw in a hi flow k&n filter. Plugged it out and plugged it all back in exactly how it was before. When I turned the car on my rpms dropped to 650 and back up to a 750 idle. Then I have a ABS light on, ESP light and a check engine light. None were on before.... so WTF??? I only unplugged the one MAF sensor and nothing else was touched. Maybe someone else here with more B5 experience can enlighten me cuz im pissed off!!!
Old Feb 21, 2008 | 11:12 PM
hiwords's Avatar
Default RE: NEW B5!!! troubles plz help!!
scan for the codes and then post back. it's hard to narrow things down without the fault codes
Old Feb 21, 2008 | 11:48 PM
euro_2nr's Avatar
So the vag com is the only way to get codes right?
chaos92287's Avatar
autozone will do it for free
Old Feb 22, 2008 | 02:57 AM
Audi_Skydiver's Avatar
Possibly the oil from the filter got on the MAF sensor and is causing problems. Just a suggestion, but also check for codes and post them here.
Josh
Old Feb 22, 2008 | 07:47 AM
euro_2nr's Avatar
Now that u mention that josh it might be oil on the maf. Am I gonna have troubles if it did or is it gonna just clear itself off...given that's my problem.
Old Feb 22, 2008 | 08:26 AM
chaos92287's Avatar
pick up some electronics cleaner from autozone or radioshack and clean the maf. has to be electronics cleaner. if the filter you bought is oiled tho, this problem will keep coming back
Old Feb 22, 2008 | 01:07 PM
turbo kraut's Avatar
Tech Guru
ORIGINAL: chaos92287
that is why you let the filter dry out a lil bit, but you can get a new maf fairly cheap online or at your local vw dealer
HenrikMeister
Jul 7, 2014 10:47 AM
lyosha
Jun 22, 2009 09:59 AM
Deathgen
May 18, 2009 09:05 AM
kp99audiA4
Dec 2, 2008 01:18 AM
alfiesride
Mar 5, 2007 01:01 AM
