No Hight Beam, Only Low Beam...
Old Feb 21, 2009 | 12:06 PM
DjSly's Avatar
Default No Hight Beam, Only Low Beam...
Ok so I searched a bit around the forum but couldn't find anything related to my problem.
When I start my car, the daylight are on. If I turn the light stick to the middle position, my interior lights turn on (day light) stays on. When I set it to the Low beam (night light) everything turns off. BOth daylight/low beam/interior light
Also, the High beam only works if I hold the stick towards myself, if I push it to have them permanent, nothing happens.
I'm guessing it's an electrical problem, but where should I start looking ?
Thanks everyone, I'm hoping to get some positive help out here
Old Feb 21, 2009 | 05:10 PM
TommyGunns's Avatar
Yeah, my brights will only stay on when you hold the stick back too. And if I have the fog lights on and the headlights, and flip on the high beams, the fog lights turn off, but I have no high beams. I'm guessing its something with the multi switch, but I'm a little intimidated about it, plus the switch assembly is $$
Old Feb 22, 2009 | 03:08 AM
DjSly's Avatar
So basically you are saying that the "switch assembly" should be the main cause ?
Can anyone else can confirm this ?
Old Feb 22, 2009 | 03:20 PM
SAudi's Avatar
yes it is the headlight switch, its $200 fromt eh dealer and it takes about an hour or so to replace if you do it yourself.
abedel2
Jun 7, 2010 02:17 PM
rbelak
Dec 12, 2007 02:53 PM
a4cab
Oct 28, 2007 01:45 AM
seattlea6
Oct 16, 2007 01:10 AM
PES_supercharged
Aug 30, 2004 03:35 PM
