No start, no compression after resetting timing. Video included.
Old Jun 3, 2020 | 10:01 PM
Monica Sekhon's Avatar
Originally Posted by Cybersombosis
Have you inspected the timing belt teeth? There is no way for the belt to turn without the crank turning too except if the teeth are stripped clean off the belt. When I say check timing, you have to put the mark on the crank to the mark on the timing cover, then remove the timing cover and check the timing mark on the valve cover from the cam gear. I suspect there is blockage in a cylinder like a dropped valve and now the engine no longer can turn over.
Doug
well, i didn't take off the lower timing cover to try and turn the crank. Im assuming the worst... the engine does not crank... the serpentine belt does turn, but that's it... the timing belt is tight and appears intact. Here is a video..
Old Jun 4, 2020 | 02:59 AM
Cybersombosis's Avatar
So it sounds like the starter is not engaging the flywheel and that may be because the starter is going or something is blocking the piston from completing its cycle like a dropped valve. Looks like you will have to get to the crank bolt to see if you can turn the engine by hand. If you can then you will have to diagnose the starter. If you can’t then my suspicion of a dropped valve is most likely true.
I just went through this with an A4 I bought with an engine not running. Same thing happened. Stopped all of the sudden. When I took the head off, this is what I found.
I ended up rebuilding the entire motor and head as a learning project.
If you dropped a valve, you will most likely require a new engine unfortunately as there will be piston damage and head damage like above.
A quick way to see if there is damage is to take the spark plugs out. If there was a valve bouncing around, the spark plug will be hard to take out and look like this. You can also shine a light down the spark plug hole to see if you can see anything but the tell tale sign is if you can’t turn the engine over by hand. Let us know what you find.
Doug
JEDGE1.8T
Oct 31, 2014 10:21 AM
Crowss
Mar 28, 2012 09:35 AM
heyduck
Aug 18, 2011 08:19 PM
cschema
Mar 2, 2011 07:52 AM
DOC_DEPALMA
Jan 4, 2011 05:53 AM
