Is this normal for the auto tranny?
Old May 16, 2011 | 05:16 PM
newhandle's Avatar
Default Is this normal for the auto tranny?
98 b5 a4 2.8Q auto w/ 115K.
When shifting into 4th, and with the gas pedal held constant, I notice an upward RPM surge of up to 300rpms before the gear is engaged. The same happens going from 4th to 5th. The first 3 gear changes are silk smooth no matter what speed the car is travelling at.
I would like to know if it's normal for the car to do the above, or should I be concerned?
Thanks
Old May 19, 2011 | 02:33 AM
Lornnn's Avatar
my car does this on the way to 3rd gear. i'll be doing an automatic transmission fluid flush and change along with replacing the transmission mount to see if its resolved.
Old May 19, 2011 | 02:53 AM
morpheous's Avatar
Thanks
No,it isn't normal,check your automatic transmission fluid level.
Old May 19, 2011 | 03:04 AM
newhandle's Avatar
Do you recommend blauparts tranny flush kit or is there a cheaper alternative?
Old May 19, 2011 | 03:25 AM
morpheous's Avatar
NO,that kit is fine...get it.
Old May 19, 2011 | 01:01 PM
jdahlen24's Avatar
The Blauparts kit works great. They also include a few extra bolts for the pan, which saved my bacon because I stripped one of them when taking them off.
Old May 19, 2011 | 03:37 PM
NickBroderick's Avatar
That happens to me, too. My tranny has been flushed twice, and it still does it, so I'm not sure if a flush will do the trick...
Old May 19, 2011 | 04:46 PM
Papa_Dios's Avatar
When/if you do the tranny flush, check the magnets in the pan for gray matter, if so thats metal from your clucth packs and start saving.
Old May 20, 2011 | 04:24 AM
newhandle's Avatar
that's just great. I was really planning on keeping the car but I guess I won't be. Next week is flush day. fingers crossed.
Old May 20, 2011 | 08:37 AM
Papa_Dios's Avatar
I hope that it's just low fluid but just giving you a heads up. BTW DO NOT FLUSH just drain and refill/change gasket/filter. Flushinng can do more harm than good sometimes.
