Is this normal for the auto tranny?
Old May 20, 2011 | 02:33 PM
morpheous's Avatar
Originally Posted by Papa_Dios
I hope that it's just low fluid but just giving you a heads up. BTW DO NOT FLUSH just drain and refill/change gasket/filter. Flushinng can do more harm than good sometimes.
This is very good advice,i was reading up on flushing/replacing ATF and it was said,that flushing is damaging to the transmission system. I second,a drain and refill.
Old May 21, 2011 | 04:02 AM
newhandle's Avatar
thanks man. My kit is on the way and will be on it early next week.
Old May 26, 2011 | 12:11 AM
newhandle's Avatar
I'm half way done with the fluid change. The magnets were coated with a thick layer of the gray matter. LOL. We'll see what happens after when I finish.
Old May 26, 2011 | 02:06 AM
Aud1A4's Avatar
that grey material is the chippin of your transmission but that should be normal
Old May 26, 2011 | 02:47 AM
Team Supreme's Avatar
Originally Posted by NickBroderick
That happens to me, too. My tranny has been flushed twice, and it still does it, so I'm not sure if a flush will do the trick...
same here
Old May 26, 2011 | 10:33 AM
Papa_Dios's Avatar
The gray matter is metal AKA your clutch packs which is NOT normal. A little gray matter on the magnets is normal but only a minimal amount is.
Old May 26, 2011 | 01:59 PM
newhandle's Avatar
These aren't the things I could have possibly checked prior to my purchase. It's twice in a row my quest for a decent german daily-driver has ended in FAIL.
Old May 26, 2011 | 04:53 PM
  #18
newhandle's Avatar
Update: Fluid change complete. Took a hard test drive. Nothing changed... pfff, however, I did notice a leak from this thing next to the oil pan. The leak is not on that thing (I don't know what it's called), but appears to be coming from somewhere above and eventually dribbles to the ground. Please see the attached image. The leak was apparent right after I stopped the car, and stopped after a few minutes. I might have overfilled the tranny fluid, but I don't know what this leak is or where it's coming from. Any ideas?
Old May 26, 2011 | 06:14 PM
  #19
Papa_Dios's Avatar
Take a better pic (wider) and point to what's leaking. Probably your input shaft seal but can't tell from that picture.
Old May 26, 2011 | 07:00 PM
  #20
newhandle's Avatar
That might be tough given the little working space I have underneath the car. I'll monitor the leak for a few days though. May be it was temp. I'll update us soon.
