O2 sensor woes... New sensor, still unhappy.
Hola AF gang! I have a '01 A4 Quattro 2.8l and it's sick...
It started last week when I was driving home from work. Felt like the tranny was engaging and disengaging (back and forth a few times) then the engine died and I rolled to a stop... CEL came on and so I plugged my VAG-COM in (yep, I carry it in the glove box) and it threw me the following codes.
16534 - Oxygen (Lambda) Sensor B2 S1: Malfunction in Circuit
P0150 - 35-10 - - - Intermittent
Here is a read on the B2S1 before I replaced it:
TID 01 - Rich to lean sensor threshold voltage Test:0.435 V
TID 02 - Lean to rich sensor threshold voltage Test:0.435 V
TID 03 - Low sensor voltage for switch time calculation N/A
TID 04 - High sensor voltage for switch time calculation N/A
TID 05 - Rich to lean sensor switch time N/A
TID 06 - Lean to rich sensor switch time N/A
TID 07 - Minimum sensor voltage for test cycle Test:0.030 V - Min:0.005 V - Max:0.385 V
TID 08 - Maximum sensor voltage for test cycle Test:1.080 V - Min:0.480 V - Max:1.005 V
TID 09 - Time between sensor transitions Test:0.160 s - Min:0.040 s - Max:1.000 s
TID 10 - Sensor period N/A
So as you can see, the Max sensor voltage was out of parameter, so I figured this is the problem and off to the auto parts store I went. After 140.00 for a new o2 sensor and fancy little o2 sensor wrench I headed for the shop. A quick 10 minutes later and I had the sensor replaced. Put the car back together, and cleared the codes before heading out for a test drive.
Not 20 blocks into the test drive, it started doing the same thing again... No CEL, just engage / disengage and then the engine dies. So I limped it back home, and tried to pull codes... Nada, zip, zilch. The ECU thinks everything is great. No codes.
I did a scan of all the o2 sensors and this is what I came up with now...
B1S1
TID 07 - Minimum sensor voltage for test cycle Test:0.195 V - Min:0.005 V - Max:0.385 V
TID 08 - Maximum sensor voltage for test cycle Test:0.675 V - Min:0.480 V - Max:1.005 V
TID 09 - Time between sensor transitions Test:0.000 s - Min:0.040 s - Max:1.000 s
B1S2
TID 01 - Rich to lean sensor threshold voltage Test:0.575 V
TID 02 - Lean to rich sensor threshold voltage Test:0.575 V
TID 07 - Minimum sensor voltage for test cycle Test:0.310 V - Min:0.000 V - Max:0.575 V
TID 08 - Maximum sensor voltage for test cycle Test:0.480 V - Min:0.575 V - Max:1.005 V
TID 09 - Time between sensor transitions N/A
B2S1
B2S2
TID 07 - Minimum sensor voltage for test cycle Test:0.410 V - Min:0.000 V - Max:0.575 V
TID 08 - Maximum sensor voltage for test cycle Test:0.805 V - Min:0.575 V - Max:1.005 V
Now it says time between sensor transition is zero?!?! WTF?!?
Any ideas?
B1S1
B1S2
B2S1
B2S2
Any ideas?
jkjersey
B7 Models
Jun 17, 2013 09:31 AM
audiblaze
Dec 11, 2011 02:08 AM
beholder
Jun 1, 2010 08:00 PM
TTsteve
May 7, 2006 12:34 AM
