Oil tempature sensor?
Old Jan 2, 2012 | 01:44 PM
A4driver17's Avatar
Default Oil tempature sensor?
Does any1 know where its located? Or how to replace it? My gauge isn't reading the tempature of my oil. Its reading at below 140
Old Jan 2, 2012 | 03:02 PM
Dallas09's Avatar
It is located on the oil cooler, where the oil filter screws on to. The pressure switch is also there I believe and I dont remember which is which, but if you unplug on of them, rev the car up and get an oil pressure light then you know it was the other one.
Old Jan 3, 2012 | 02:20 PM
A4driver17's Avatar
What would I need to look for to find it? And how easy is it to get to the sensor??
Old Jan 4, 2012 | 02:22 AM
Dallas09's Avatar
Look for a single wire connected to the oil cooler (they are grounded through the metal casing).. Its easy enough to get at when you take the 4 screws off of the coolant tank and move it out of the way.
Old Jan 6, 2012 | 11:47 AM
Mike-2ptzero's Avatar
IIRC, on my A4 the oil pressure sensor is the one on the back of oil cooler while the one on the bottom of the pan is the oil temp sensor.
BTW there is only 3 screws that hold the coolant tank in place.
A4driver17
Jun 23, 2011 11:49 PM
JcoyA6
Apr 16, 2008 06:46 PM
trejo21
Nov 1, 2006 02:29 AM
johnstef
Sep 5, 2006 03:49 AM
nazar2350
Mar 17, 2006 05:54 PM
