One headlight.... Still
Old Jan 17, 2010 | 05:29 PM
audi_n00b's Avatar
Default One headlight.... Still
I had a vvme HID kit and the driver's side light went out so I bought a ddm tuning kit and swapped those in. The driver's side light STILL isn't working! Is there a fuse or something I need to check?
Old Jan 17, 2010 | 05:38 PM
209AudiGuy's Avatar
did you try turning the light on then of then back on again? i have the ddm 3000k hids in my fogs, sometimes the ballast doesnt turn on. but if i turn it off then back on again it will turn on. kinda weird i know. but they work fine.
Old Jan 17, 2010 | 05:45 PM
ImTheDevil's Avatar
The fuse panel in the driver's side of the dashboard has individual fuses for each headlight. If they're both fine, and you still have a light out, swap ballasts side to side and see if the issue follows - that'll tell you if you have a bad ballast. If not, it is either a bad bulb (which you can then swap to see if the bulb is bad) or a fault in the wiring somewhere, which will require some time and patience with a multimeter.
Old Jan 18, 2010 | 01:51 AM
audi_n00b's Avatar
I'll check the fuses tomorrow. I was wondering if there was only one fuse for both headlights but if they're separate fuses I think that might be the issue. I would assume it wouldn't be a ballast or bulb issue considering the kit is brand new. But if that is the problem I'll be having a chat with ddm tuning...
Jrmiller
Feb 25, 2013 03:03 PM
Influentialstylez
Mar 29, 2007 04:30 AM
rkohan
Mar 20, 2007 04:16 AM
