power windows
Old Mar 17, 2008 | 12:54 PM
skeet1966's Avatar
Default power windows
My power windows stopped working one morning. I checked the fuses in the fuse box inside the car and seem to OK. Is there another fuse box other than inside the car? Has anyone else had this problem, please reply?
Thanks
Old Mar 17, 2008 | 01:37 PM
01AudiA4's Avatar
Default RE: power windows
Should be one in the engine bay, on all my other cars there were. Never really checked it out on the audi.
Old Mar 17, 2008 | 09:37 PM
thepirate's Avatar
did it just stop? or is it making grinding noises?? i've had to replace all my window regulators in my 01 A4 two of the windows twice.....if its grinding take off the door panel and check to see if there is play in the cable that moves your window up and down...
Old Mar 19, 2008 | 01:01 PM
bradisonn's Avatar
I too am having problems with my window. I opened up my door panel and saw that the wire was just messed up. The motor and everything runs fine, Ijust havent had time to mess with a new wire.
Old Mar 19, 2008 | 05:18 PM
thepirate's Avatar
ORIGINAL: bradisonn
if you are talking about the cable that moves the window up and down, then you need a new window regulator. check out www.egermanparts.com i've ordered all my regulators from them, two broke on me (after having them for 6 months) they sent me two more free of charge! i had to send them my old ones after i put the new ones in though for some kind of warrenty thing.
Old Mar 19, 2008 | 05:57 PM
A4speed's Avatar
ive replaced 3 and yes, you have to replace the whole unit because they don't sell the individual parts, the stealership wants ur $$$ . it is a common problem with our cars.
Old Mar 20, 2008 | 04:51 PM
bolob5's Avatar
Off topic: The one touch window down option on my car sometimes works and sometimes doesn't... Anyone heard of this problem or know what modulator it is?
Thanks
Old Mar 20, 2008 | 05:13 PM
thepirate's Avatar
mine has done that before as well. you might have to reset your auto up/down switch. i dont know off hand how to do it, i think it involes something with the key in the door??? i know my windows will roll down if i put the key in the door and hold it to the right....
anyone know how to reset the window switch?
Old Apr 28, 2008 | 02:37 PM
jogabonito14's Avatar
This Just happenned to me this morning did you find out what it was????
Old Apr 29, 2008 | 02:25 PM
crsf29's Avatar
I know that if you disconnect the battery for some time the windows lose the one touch feature for a little bit. At first I was worried and rather pissed, but I rolled them up and down a few times each, and dealt with it for a day, and then they started working again. Not sure what it was that fixed it, but something did. Maybe rolling them all up and down (incl. sunroof), or maybe doing it multiple times on different starts. Im not sure, but something worked. I didn't do anything with the keys or anything, audi magic works in strange ways...[&:]
Good luck!
A6mark
May 30, 2013 02:12 PM
suuntotim
Jul 25, 2011 12:36 PM
Audacity
Aug 29, 2009 08:20 PM
99BlackA4
May 22, 2006 08:43 PM
