Quattro staggered question
Old Feb 7, 2010 | 02:15 PM
sdsteez's Avatar
Default Quattro staggered question
I know it's bad to run an actual staggered setup on the quattro, what about running 17x8s all around but running different sizes spacers. After mounting the wheels on the S4 I'm thinking maybe 15mm front/20 or 25mm rear. Would this be as detrimental to the quattro as running an actual staggered set up? Tires are 205/45 all around.
Old Feb 7, 2010 | 02:19 PM
hiwords's Avatar
there are several people who run stagger for years without any diff problems. different size spacers is ok too but with spacers, your wheel bearings will not like you very much. as long as your overall diameter including tires are within 5% of each other you should be fine
Old Feb 7, 2010 | 03:17 PM
kriptonik's Avatar
Staggered isn't bad for Quattro as long as you get the overall diameter to be REALLY close.
Spacers won't effect the Quattro at all.
Old Feb 7, 2010 | 06:21 PM
ImTheDevil's Avatar
Agreed with all of the above. If you order new wheels at some point and want to maintain that look, order one pair with the "correct" offset and the other pair with an offset 10-15mm different. That way you'll have the same width wheel, same rolling tire diameter, but a deeper lip on the rears.
Old Feb 8, 2010 | 04:51 AM
Quattros's Avatar
rolling diameter as the other randy is correct, must be with 3-4% of oem specs to not create a problem.
ideally, you can run 225/35 with 245/35 rear...if i am not mistaken
dstamatoiu
Aug 30, 2013 01:33 PM
Donman19
Mar 1, 2012 01:21 PM
catch
Jul 3, 2008 02:20 AM
Amze
May 24, 2007 05:54 AM
pecas61
Nov 11, 2006 07:47 PM
