Question about ABS Light
Old Feb 12, 2008 | 10:50 AM
deneb's Avatar
Default Question about ABS Light
Hi,
Couples month ago, I got the abs light and brake light on. So I checked on internet and on this forum to know what happened. I finally went to an audi dealer and they said that the abs module was "broken" and It was like 2000$ bucks to repair it !!! Too expensive for me lol
I would like to know if there is a cheap way to repair it ? I saw that a company repair some of the module but I do not know if it still the case. I check on ebay but i have found lots of abs module
Any idea ?
Thanks guys
[align=right] [/align] Post #: 1 // RE: Question about ABS Light - 2/11/2008 8:20:57 AM showPicture("2/11/2008 8:20:57 AM",1,0,0,797484,7) camhabib
titleAndStar(22,0,0,false,",")Newbie
[align=center][/align]
Status: offline I believe that the ABS system Audi uses is comprised of three parts, a computer, pump, and pressure modulator. I believe it is possible to replace one of these parts independent from the others, which is what rebuilding the ABS does. If you can find someone to do it for cheaper and they seem reliable, it might be worth the risk. I would personally rather just buy the part new, seeing as the whole braking / ABS system is a little more important safety wise then something such as a radio or the like. [align=right]
(in reply to deneb) [/align] Report | Post #: 2 RE: Question about ABS Light - 2/11/2008 4:02:23 PM showPicture("2/11/2008 4:02:23 PM",1,0,0,797484,7) brownrice
titleAndStar(8,0,0,false,",")Newbie
Status: offline check out module masters. its 200 bucks to fix.
Are they reliable ?
http://modulemaster.com/index.html
Thanks
Old Feb 12, 2008 | 11:06 AM
Crunk's Avatar
Default RE: Question about ABS Light
My ABS lights are on and it is just a computer chip that will cost $145 including Labor. Did you get it Scanned? I would recommend taking it to a reputable Audi certified repair shop, instead of the Stealership and see what they say.
Old Feb 12, 2008 | 12:44 PM
deneb's Avatar
Yes, I performed the scan at my audi dealership, and the result was that the module was dead, and it was like 2000$ to fix it
Old Feb 12, 2008 | 12:56 PM
techbod's Avatar
and they gave no fault code? that's disgusting and a price rip, next time ask for the fault code or ask them anyway since you paid for that and they should have given you that at least as proof[:-]
Old Feb 12, 2008 | 01:04 PM
techbod's Avatar
# you can test the ECU with a multimeter
[IMG]local://upfiles/12092/4A2F68EB2EA74BC3BB03E562092BE81C.jpg[/IMG]
Old Feb 12, 2008 | 01:44 PM
Crunk's Avatar
ORIGINAL: deneb
If you haven't had it fixed yet.....Take it to EuroSports in Plano.....It will be worth your time!!
Old Feb 12, 2008 | 01:52 PM
diesela4's Avatar
all you need is to find a matching motor at the scrapers and take the ABS brain from it should only be $50 Used - works a treat
Old Feb 12, 2008 | 09:01 PM
Trey25's Avatar
I couldn't hold out to find the elusive M abs module so I'm sending mine to these guys. For 3 day turn around and a lifetime guarantee $140 ain't bad.
Old Feb 12, 2008 | 10:00 PM
kendalll's Avatar
www.modulemaster.com
www.autoecu.com
www.bba-reman.com
probably more?
Old Feb 14, 2008 | 06:28 PM
deneb's Avatar
Could you let me know when it is done please ? If it is fast and that you do not have any problems I will sent mine to them
v8_ranch
Aug 27, 2012 12:45 AM
numlock4045
Feb 9, 2011 07:12 AM
superdooperme
Oct 9, 2008 12:15 AM
beckmaster
Apr 13, 2008 08:39 AM
