Random misfire and more 2000 Audi A4 2.8
Old Nov 18, 2012 | 02:43 PM
cshea85's Avatar
Default Random misfire and more 2000 Audi A4 2.8
I recently bought a used A4 for my little sister, now its getting a bad misfire under from stop accel, to about 40 mph when its finally no longer noticable. Shows up mainly under heavy load on the engine i.e. Accel from stop or slow speeds up hills. She had the coil packs replaced before i could get a chance to work on it ( she lives 7 hours away ). I also replaced the #3 Fuel injector because of the codes that it brought up.
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,16,17,25,35,37,45,55,56,57,67,75,76 ,77
Address 01: Engine Labels: 078-907-551-ATQ.LBL
Controller: 3B0 907 551 G
Component: 2.8L V6/5V G 0050
Coding: 07251
Shop #: WSC 09401
VCID: 2721BF81D6E3
5 Faults Found:
17635 - Fuel Injector for Cylinder 3 (N32): Short to Ground
P1227 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16687 - Cylinder 3: Misfire Detected
P0303 - 35-00 - -
17831 - Secondary Air Injection System; Bank 1: Insufficient Flow
P1423 - 35-00 - -
17819 - Secondary Air Injection System; Bank 2: Insufficient Flow
P1411 - 35-00 - -
Readiness: 0110 1101
I could believe the 16684 error code to be possibly plugs and wires, but the short to ground on injector 3 is what i was hoping for advice for. Thanks for any help
Old Nov 19, 2012 | 11:39 PM
sick_vdub's Avatar
Go for the basics, spark plugs wires( spray with water and see if they shooting through) and the coil if after market might be defective,,....
dakiddc973
Mar 7, 2014 08:23 AM
darksoldier313@yahoo.com
Sep 3, 2010 07:31 PM
bandaru37
Dec 9, 2008 08:15 PM
