Rear Brake Clicking noise when e-brakes engaged
Old Aug 7, 2012 | 03:26 PM
o_a_ravi@hotmail.com's Avatar
Default Rear Brake Clicking noise when e-brakes engaged
Hi,
I recently replaced my rear Rotors are Pad on my 2001 A4 B5 Quattro. The installation was fine AFAIK.
However after few days of the job, i see a clicking/poping noise when the car is parked with the e-brakes engaged. Can hear the sound when the car is shaked while trying to open the doors etc.
The sound is coming from the driver side rear. Only when the e-brakes are engaged and vehicle is stationary. (with a slightest move)
I did use the brake quite compound over the pads. verified the caliper, carrier and the lug nuts are tight to its specified torque.
Do someone out here experienced this before ?
Old Aug 7, 2012 | 05:26 PM
z28pete's Avatar
May want to take a look at the parking brake cable as it may have been moved when you replaced the pads, and now is touching something it shouln't.
Old Aug 29, 2012 | 02:16 PM
On further inspection, I found that the pads that sit on the frame is little loose. And i could feel a little ply.
I suspect that this ply is causing the pads to knock the housing while applying the brakes in low speed, or when the E-Brakes are engaged and the vehicle has a linear movement.
Tried swapping the pads inner <> outer, and adjusted the anti-rattle springs and re-installed. The issue was gone for few days, but back again.
I think it should not be a big issue other than the annoying noise.
Old Aug 30, 2012 | 06:18 PM
z28pete's Avatar
Did your new pads caome with shims to adjust for wear on the caliper carrier where the end of the pads rest against?
Old Aug 30, 2012 | 07:05 PM
I dont think it had the shim on it. All it came with is the spring on the top.
Here is the picture of the pads. And these are from ECS Tuning : Audi B5 A4 Quattro V6 30v > Braking > Pads > Rear > ES#2093769 Rear Brake Pad Set - 4D0698451F
http://c1552172.r72.cf0.rackcdn.com/152326_x600.jpg
The pads just slides in to the carrier with the rotor in between.
Raddue
Feb 9, 2015 10:47 PM
Cocody18
Jun 15, 2013 06:38 PM
egos_86
Nov 18, 2010 12:23 PM
M3Armand
Dec 11, 2006 01:41 PM
AteUrV8
May 24, 2006 11:14 PM
