rear coilover installation audi a4
Old Nov 28, 2009 | 10:38 PM
Stevenw83's Avatar
Member
Default rear coilover installation audi a4
when installing my new kw v1's rear coilovers on my 2.8q.. i noticed that when i removed the jack the car was higher than stock wtf im retarded (note the coilovers were as low as they could go)! everything was in place! is it possible that the arm that extends from the coilover bracket housing was moved causing the control arm to be lower than possible. Please help my dumbass and to clarify this is what i read from a forum on coilover install.
----The last two bits are to be done with the car on the ground, according to Bentley. The idea is to avoid preloading the suspension bushings. Good luck with the upper control arm bolt; I'm sure you could fit a torque wrench around the tire easily, provided you remove the fender. Instead, I just jacked up the suspension a few inches to simulate being on the ground.
My fellow audi enthusiasts please help me for this is my first time doing this.
Thanks
Old Nov 28, 2009 | 11:02 PM
flynnr's Avatar
just a thought, are you SURE they are as low as it could go, not as HIGH as it could go?
sorry to be an *** like that, but the other day i was on my way out the door in a rush, and couldnt find my keys... looked all over the couch just to realise they were in my hand the whole time (got to stop smokin the wacky tabacky!) lol jk
hope this helps?
either that or maybe they just need time to settle?
Old Nov 28, 2009 | 11:31 PM
TeeterTawter's Avatar
thats strange, did you install everything correctly? heres a pic of what my rear coilover looks like installed.
and this is how my car looks like first time letting it off the jackstands after the install.
installed like 3 years ago.
Attached Thumbnails rear coilover installation audi a4-coilover.jpg   rear coilover installation audi a4-untitled.jpg
Old Nov 28, 2009 | 11:33 PM
I have koni coilovers btw.
Old Nov 29, 2009 | 03:20 AM
Stevenw83's Avatar
Member
nope i even turned them all the way to the top and the car looked like a dune buggy so i rules that out. I doubt they need to settle for it was at stock height.
Old Nov 29, 2009 | 03:49 PM
hiwords's Avatar
put up some pix. you sound like you know what you're doing but maybe you made a minor error somewhere that we may pick up in a pic.
Old Dec 1, 2009 | 11:44 PM
M3Armand's Avatar
+1 on posting pics. We can't help you if we can't see what you're seeing...
Old Dec 2, 2009 | 12:01 PM
ImTheDevil's Avatar
If you turned the seats and collars to the top then you've lifted the car. The closer the perches are to the road, the closer the car will be to the road. To put it another way, the more strut you have inside the coil spring, the lower you'll be. Lower the spring perches to lower the car.
JTmotorsports702
Mar 31, 2012 04:17 PM
shortyxc
Jul 13, 2009 11:41 AM
MC Hammered
Jun 8, 2007 03:48 AM
newyorkgiants44
Apr 27, 2007 05:29 PM
TurboQuattroPwr
Sep 11, 2006 11:41 PM
