Rear Wheel Bearing Change Without Machine Press - Possible?
Old Apr 11, 2010 | 10:06 PM
jophish's Avatar
Default Rear Wheel Bearing Change Without Machine Press - Possible?
I have to change my drivers' side rear wheel bearing. I'm curious if there's a way to do it without a machine press. If i could use a hand operated one that'd be a hell of a lot easier. Just curious.
Thanks in advance,
Joe
Old Apr 11, 2010 | 10:27 PM
hiwords's Avatar
i believe you need a 3 ton bearing to get it in easily. by hand operated you mean a jack setup right? make sure you press the right spot
Old Apr 11, 2010 | 11:04 PM
jophish's Avatar
i'm going to check tomorrow if i can use the machine shop here at school (a bit dicey since i'm an architect and it's in the engineers' territory). But i think they've got a hydraulic press that'd save me a lotta hassle. Although in the end if all a shop has to do is press the bearing in it's probably not going to cost me that much and would be a better use of my time.
Old Apr 12, 2010 | 02:52 AM
Mr. Phil's Avatar
i did mine with a hydraulic press... hand operated.. but im fwd and my rear bearings are a 2piece so idk if u have quattro then it should be a 1 piece... but if it is a 2 piece then as long as u get the race pressed in right then u shouldnt have a problem
Old Apr 12, 2010 | 03:35 AM
jiggleo's Avatar
I used a porta-power one time. I would have driven it down to a shop if I had a second car at the time. I wouldn't recommend it. It worked just wasn't pretty.
Old Apr 12, 2010 | 08:02 AM
ImTheDevil's Avatar
The online DIY uses a HubShark press that doesn't require removing the spindle from the car. If you have access to one of those it can be done.
Old Apr 12, 2010 | 05:20 PM
Mr. Phil's Avatar
well he still never told us if hes quattro or not
Old Apr 12, 2010 | 09:15 PM
jophish's Avatar
yes it is quattro. I'm just going to pull the spindle and bring it to a shop and have them press it for me, the guys here are good and don't break your leg so i'll be fine.
Kyle_vdk
Jan 11, 2014 10:25 PM
midnightride42
Feb 22, 2011 04:52 PM
smoovmusicdj
Jan 11, 2008 03:46 PM
Ed1955
May 3, 2006 04:52 PM
hotrod
Mar 8, 2006 01:11 AM
