Rear window problem . . .
Old Jun 23, 2012 | 11:02 AM
eelpie's Avatar
Default Rear window problem . . .
Today I rode around with my rear windows down, and when I went to put them back up, the LR balked.
I could get it half-way up, and then, as if hitting a sensor, it would partially retract again.
I managed to coax it all the way up manually, and I don't use it often at all, but I don't like things broken on the car.
Is it likely the motor, the regulator, the track, or what?
I've never taken a back door-panel off the car, so I'm venturing into new territory here . . .
Old Jun 23, 2012 | 11:32 AM
mtroxel's Avatar
You know you're getting power to the door, and you know the motor is probably fine. If the window stops at the same place every time, I'm betting it's the regulator. You're going to have to take it apart. I'll bet you'll see something broken, like one of the guides that the window slides on.
Old Jun 23, 2012 | 11:36 AM
eelpie's Avatar
Default Thank you for the in-sight . . .
Any hints on removing the door-panel?
Once I've got that off I'll be able to assess the damage, and determine what I'll need . . .
Old Jun 23, 2012 | 12:02 PM
mtroxel's Avatar
Old Jun 23, 2012 | 12:14 PM
eelpie's Avatar
Default one of the clips probably broke off on your window regulator that keeps it straight
Is it possible to replace the clip or clips that broke?
Old Jun 23, 2012 | 12:16 PM
mtroxel's Avatar
We don't know what broke yet.
Old Jun 25, 2012 | 09:45 AM
eelpie's Avatar
Default It's the regulator . . .
I took the door panel off, and I found the white pulley wheel in the bottom of the door, broken in two.
Has anyone ever tried one the of the repair kits off of eBay?
I think that might be preferable to a used regulator from a knacker's yard or eBay, as they'd already be aged and used . . .
Old Jun 25, 2012 | 09:50 AM
mtroxel's Avatar
I disagree. On the average car, 3 of the 4 windows hardly get any use. I'd go with a used one off of any door except the driver's door if you can get it.
Old Jun 25, 2012 | 11:22 AM
eelpie's Avatar
Default I’ve called my mechanic . . .
I’ve called my mechanic and he’s going with a new after-market regulator. For the modest difference in price I can get it done tomorrow morning and be done with it.
I am in Colorado and we’re experiencing seasonal weather . . . for Arizona, and getting it done quickly and painlessly is a better option that taking a week to find a second-hand regulator.
In addition, letting him make a couple of bucks will stand me in good stead if I ever really need a break or if there’s ever an emergency . . .
indelible.eggs
Jul 25, 2013 10:27 PM
lord_of_lostock
Mar 28, 2013 02:59 PM
kris453
Aug 24, 2008 08:28 AM
hxgaser
Dec 20, 2007 07:15 PM
nykxx
Jan 12, 2006 10:11 PM
