Rear window problem..please help
Old Aug 23, 2008 | 11:54 PM
kris453's Avatar
Default Rear window problem..please help
Hi,
My rear window on the passenger side has a wierd problem. It goes down when i press the switch but wont go up.All i am doing now is manually lift the window with hands and close the window but when i am driving and there is a bump the window starts going down again. I am not sure if there is a seperate motor for getting the window down and getting the window up? because if there is just one motor then my window should not go down if i press the down switch.
Please help.
Old Aug 24, 2008 | 08:24 AM
andry's Avatar
i would start check the switch. i feel, the power window switch is bad, also please check the power window motor.
the most problem on power window is switch, motor and fuse.
Old Aug 24, 2008 | 08:28 AM
andry's Avatar
also, check this thread...the problem is similar with you.
https://www.audiforums.com/forum/sho...d.php?t=110854
indelible.eggs
Jul 25, 2013 10:27 PM
lord_of_lostock
Mar 28, 2013 02:59 PM
eelpie
Jun 25, 2012 11:22 AM
hxgaser
Dec 20, 2007 07:15 PM
nykxx
Jan 12, 2006 10:11 PM
