should these rear wheel bearings have this little grease?
they dont seem like they have enough to me.
see my post in general tech, thanks
https://www.audiforums.com/forum/sho...94#post1017694
thanks.
that is just what i wanted to hear.
if all these bearings come this way, its no wonder they have such a short life, they would run dry in no-time.
that plus the way the wheel is cantilevered out loading the bearing in kind of a bearing mode rather than radially...
yeah, i know. I guess i should have been more clear.
it was the NEW bearings that i was preparing to install that had hardly any grease in them. the old ones were shot, thats why i was replacing them...
i dont see how these could live very long with that little lube in there
i dont see how i could have ruined anything by taking them apart. they are not held together by anything other than the seals, and they were easily finessed out of place.
these are not what i would typically think of when i think of sealed bearings, those are indeed practically impossible to get apart without destroying. these guys would fall apart if you dropped one on the ground.
Like i said earlier i dont know if that grease in there is supposed to be magical, but if you packed some old school tapered roller bearings with only that small amount of grease, they would be toast in no time..
I guess I will be my own personal guinea pig for this one, but from what it sounds like its not uncommon for these bearings to have irregulary short life i would rather not go through this again any time soon
Keep your fingers crossed you haven't shortened the bearing's life considerably by compromising it's seal. Other than flat-spotted ***** or broken cages from pot holes, the next leading cause of failed wheel bearings I've seen is due to rust and dirt due to a failed seal.
Broncoman75
Jan 2, 2009 01:11 AM
