spark plug oil
Old May 28, 2009 | 01:14 PM
joe99a4's Avatar
Default spark plug oil
ok so my spark plugs are drenched in oil. I know i need to replace the valve cover but what would be a good way to get the oil out from the spark plug cylinder area? I am going to change the valve cover today.
Old May 28, 2009 | 01:30 PM
acetrebo's Avatar
Is the oil in hole around the spark plugs, or do you mean inside the cylinder? If it's just around the plug, stick a rag in there to soak up as much as you can, or paper towel, then remove and clean the spark plug and coil pack connector.
Old May 28, 2009 | 02:44 PM
Midniteoyl's Avatar
Shop-vac...
Old May 28, 2009 | 03:07 PM
Mckayiva4's Avatar
when you replace your vave covers you should also replace your spark plug well o-rings. They should come with the valve cover gasket kit
Pilipenko
Nov 28, 2011 10:06 AM
ee99ee
Oct 12, 2011 12:28 PM
khj677turbo
Oct 27, 2007 11:43 PM
Audi_Skydiver
Sep 29, 2007 02:40 PM
AudiTurbo
Jan 16, 2007 11:45 PM
