swap A4 5 speed tranny w/ S4 6 speed
Old Dec 29, 2007 | 02:41 PM
mschwister12's Avatar
Default RE: swap A4 5 speed tranny w/ S4 6 speed
expensive
Old Dec 29, 2007 | 05:24 PM
CLX's Avatar
CLX
Zombie Defense Force
ORIGINAL: 01afour
is there any advantage to doing a 6 spd swap? and no its not possible to simply switch it out but its possible. if your gunna do an engine and tranny swap you would probably save a hugh headache and some money if u just buy an s4.
6-speed for more awesome gears! But, you could always do the ricer move and put a 6-speed **** on a 5-speed, or better yet, on a tiptronic!
Old Dec 29, 2007 | 07:39 PM
djmika's Avatar
So if I'm reading some of these posts correctly, it is possible to swap a B6 6-speed from a 1.8 or 2.0T into a B5 without having to do any major modifications?
Did they put a 6-speed behind a 1.8 in the B6 cars?
Old Dec 29, 2007 | 11:28 PM
CLX's Avatar
CLX
ORIGINAL: djmika
So if I'm reading some of these posts correctly, it is possible to swap a B6 6-speed from a 1.8 or 2.0T into a B5 without having to do any major modifications? Yes
Did they put a 6-speed behind a 1.8 in the B6 cars? Yes
Old Dec 30, 2007 | 08:33 AM
BaconBait's Avatar
ORIGINAL: CLX
ORIGINAL: Zrowcool
direct swap. will need to use the tranny mount off the passenger side of your 5 spd and the clutch/flywheel from your current engine. as far as the 2.7t 6 spd swap its possible. must change the axles, rear diff, k member as well as engine and trans of course. also need to rewire abs and the cluster/ecu
Don't you mean, center diff?
No. The center diff is in the transmission. You need to swap the rear diff so that the gearing ratio isn't fubar'd. You're also going to need a driveshaft.
I was under the impression that you could keep the stock axles. Talked to a VW/Audi/Porsche tech that said you don't have to swap the motor out since the 6 speed tranny actually has 2 sets of holes in it and will bolt to a 1.8t. I might visit a wrecking yard and match them up to check it out.
Old Jan 3, 2008 | 12:31 PM
DJTR's Avatar
that could be an interesting upgrade if its just a straight swap. tranny for tranny.
nothing77
Sep 28, 2022 01:42 AM
Michael.dwyer123
Oct 5, 2013 10:08 AM
ogemtakool
May 23, 2013 02:57 AM
Papa_Dios
Aug 3, 2011 09:43 PM
PhatPipe
Aug 15, 2007 10:50 PM
