TB question + advice needed
Old Feb 7, 2013 | 11:40 AM
jssteinke's Avatar
Default TB question + advice needed
long story short I got in a wreck with my audi and I found a nick on the timing belt the other day ( pic above)
My question is...the timing belt was replaced by an Audi dealer only 32k miles ago, so do I need to do the full kit (water pump, tensioner, etc) or just change the belt?
I plan on doing it soon (<5k miles), probably spring break or summer
thanks
Old Feb 7, 2013 | 12:12 PM
CCA4's Avatar
32k miles isn't a lot for the water pump, t-stat, etc, so you should be good there. With the hydraulic tensioner, you always want to replace it when you remove the belt. Some people just jam it back in but I don't trust that method.
Old Feb 7, 2013 | 12:43 PM
redline380's Avatar
Legal Moderator
if that only a surface scratch i wouldnt even worry about it. it the center of the belt that does the most holding. but i cant tell. if its deep enough and you are going to change the belt, you might as well change everything in my opinion. you'll be happy if you plan on keeping the car
Old Feb 7, 2013 | 08:58 PM
jssteinke's Avatar
okay. I will most likely wait until summer to do it. scratch isnt too bad. if I find a good deal on a kit without t-stat I'll buy that. Or just one with a tensioner.
thanks
Old Feb 7, 2013 | 10:34 PM
ImTheDevil's Avatar
Honestly I would do it all. You're 90% of the way to changing it all by the time the t-belt comes off. Leave the other stuff in there and in another 30k miles, halfway through the service life of the new belt and tensioner, you'll have to tear it down again for those parts you elected not to change. Just do it all at once and be done with it for another 60k miles.
Old Feb 8, 2013 | 08:43 AM
CCA4's Avatar
Good points by those two, I retract my previous statement.
Old Feb 8, 2013 | 09:29 AM
jssteinke's Avatar
Alright. Ill be keeping an eye out for a deal on a kit. thanks guys
Old Feb 8, 2013 | 09:39 AM
CCA4's Avatar
I've used timing service kits from Blauparts and FCP Groton, and am very happy with both. FCP usually has better prices though.
fabdar
B8 Models
Jul 7, 2015 04:19 AM
b007
Aug 4, 2011 09:42 AM
jth7708
Jan 27, 2007 03:09 AM
AndyMann
Jun 20, 2006 10:47 AM
raph1978
Jan 20, 2005 10:10 PM
