trubo only pushing 5psi
Old Jan 28, 2011 | 11:30 AM
  #31
madmitch105's Avatar
OK, after skimming through this thread I'm fairly certain my boost gauge is rigged up wrong or something. I didn't install it, the kid before me did, nor have I done a single thing to the car since I bought it. He said all it had done was that boost gauge and a chip. But anyways, my boost gauge tops out at 18 when I floor it to 6000 rpms, is that normal?
Old Jan 28, 2011 | 11:40 AM
  #32
CCA4's Avatar
If the guy before you got a chip installed that pushes 18psi, he SHOULD have added more than just a boost gauge.
Old Jan 28, 2011 | 02:44 PM
  #33
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
No. The stock turbo should not be pushing 18psi at 6000rpm. The few times I go all the way to 6k my boost has dropped to somewhere between 5-10psi. Anything past ~5k or so and boost is decreasing.
I'm not sure how you could rig up a boost gauge incorrectly though. Tap a vacuum line and supply power if necesary. Thats it. What gauge do you have?
Old Jan 28, 2011 | 04:15 PM
  #34
chocalotstarfish's Avatar
Super Moderator
TPAM he said it was chipped. A chip will make 18psi....
Old Jan 28, 2011 | 04:17 PM
  #35
Not at 6000rpm on the stock turbo it won't.
Old Jan 28, 2011 | 04:46 PM
  #36
Got_A4's Avatar
alright guys so i re did the boost leak test check for any holes on the charge pipes and around the TB and no hole, i did notice some oil on the inside of the TB, and everything was negative. I installed the boost gauge and made sure there where no kink/pinch's in the line and took it for a number of test pulls all max out at 5psi sometimes spiking at 6 and after 6k boost goes down to zero on the gauge, at idle the car vacuums at 22. i also heard a weird clicking noise coming from the passenger side almost sounds like lifter noise but after the car gets warm it goes away like MAGIC
Old Jan 29, 2011 | 05:04 PM
  #37
Got_A4's Avatar
who thinks my car is suppose to boost 5psi spiking 6
Old Jan 29, 2011 | 05:21 PM
  #38
I don't, you're in limp mode.
I had my own experience with limp mode after I installed my 007. I put a shim in the DV to increase the spring pressure a little, however I installed the shim on top of the spring blocking the vacuum port = limp mode.
As soon as I put the shim on the bottom of the spring like it should be, problem was solved.
Not one of my smartest moments.
Old Jan 29, 2011 | 07:50 PM
  #39
Got_A4's Avatar
yeah thats my next purchase forge diverter valve and podi guage
Old Jan 30, 2011 | 01:49 PM
  #40
I may have exaggerated a little about the rpm's but it definitely hits 18, it's a VDO gauge. I'm not terribly concerned about it, just something that until now I thought was normal.
