v6 cam lock tool
Old Oct 22, 2009 | 12:26 PM
salvador's Avatar
Default v6 cam lock tool
whats up guys im looking for that infamous cam lock tool to finish this timing belt job. i kinda wanted to stay away from actually purchasing the tool because this regular maintenance is starting to get expensive. maybe i can rent it from some one that has it in my area. thanks
Old Oct 22, 2009 | 01:43 PM
ImTheDevil's Avatar
If you set the job up correctly by indexing cylinder #3 at TDC on the compression stroke, the cams will be sitting on the flat parts of the lobes and you won't need to lock them. When our crew has had t-belts off, we wouldve had to hit the sprockets with a hammer to turn them. If you didn't set it up that way, lock them in. Get a drilled piece of flat stock at Lowes and make your own locking tool.
Old Oct 22, 2009 | 11:03 PM
salvador's Avatar
a drilled piece of flat stock, im not sure i follow..my uncle gots everything on but the timing belt. he took off the passenger side sprocket so now its spins free.
Old Oct 22, 2009 | 11:25 PM
ghost6303's Avatar
http://www.toolsdirect2you.co.uk/upl...ducts/5180.jpg
thats what it looks like. you dont necessarily need the 90* bends, it can just be a strait bar. just drill the holes on center and you are good. if you search you can find more pictures.
bshusted
Jul 31, 2013 08:46 PM
savantv
Apr 24, 2012 08:00 AM
john@astigracing.com
Jan 4, 2010 03:06 PM
audi ops
Jan 7, 2008 05:44 PM
