Wastegate question/issue.
Old Jan 27, 2012 | 12:03 AM
EuroSlut's Avatar
Default Wastegate question/issue.
My question is, is the wastegate on the K04 vacuum controlled or pressure controlled.
My issue, couple of days ago I took out my N75 valve because I was having some issues and I notticed one of the vacuum lines was pinched. When I put the N75 back in and drove the car, I could not boost past 4psi. I left it for a day like that because I didnt mind that much plus saved some gas. Today I was running some tests to see what the problem was. I hooked up the compressor line straight to the waste gate to see if I would get max boost, but it still would not go past 4psi. So then I had an idea and I connected the waste gate vacuum line to the intake/charge pipe and I plugged the compressor line. I tried that out and that got me to 20 psi which was what it was at before so I was happy. Next thing im going to do is order a mbc, and see if that helps.
Any one have any ideas or thoughts, I would appreciate the help.
Old Jan 27, 2012 | 12:09 AM
cincyTT's Avatar
I'm make believe
It's pressure based. It receives a vac line from the charge pipping. There is a 4-5psi spring inside and when the pressure gets near that amount it cracks open and stays open to maintain that pressure.
Old Jan 27, 2012 | 12:37 AM
EuroSlut's Avatar
So why wont it go past 4 psi when i connect the waste gate directly to the compressor housing?
Old Jan 27, 2012 | 09:39 PM
cincyTT's Avatar
I'm make believe
Because there is no boost control. The only thing regulating psi is the waste gate and that's set to 4psi.
Old Jan 28, 2012 | 12:28 PM
EuroSlut's Avatar
Ok so youre basically saying when I get the mbc my problem would be fixed?
Old Jan 28, 2012 | 02:33 PM
cincyTT's Avatar
I'm make believe
Mbc or n75 between boost reference and wastegate
Old Jan 29, 2012 | 05:40 PM
EuroSlut's Avatar
Ok thank you sir! I ordered my MBC so ill update on status once it comes in.
Old Jan 31, 2012 | 03:55 PM
EuroSlut's Avatar
Just put in the MBC today, works like a charm. So happy to have my boost back!
pablomigraine
Mar 23, 2015 10:20 AM
EmbraceEphemeral
Feb 4, 2012 08:58 PM
A4 2000
Feb 15, 2011 11:58 PM
DRWonoski
Oct 9, 2010 07:54 PM
boney
Feb 10, 2006 08:01 PM
