water in engine oil
Old Feb 15, 2011 | 10:20 AM
harry03a4's Avatar
Thanks for the reply...8 bucks for an oil cooler? Wow thats cheap looked on ecs and it was like $56.00 where did you get it for $8.00??
Old Feb 16, 2011 | 02:04 AM
ubdevoid's Avatar
it was actually from a self serve auto wreckers. I don't know if you guys have these in the states. Basically its a huge lot full of cars were people can help themselves to parts they wont for very cheap.
I got the oil cooler out of a VW Passat.
Old Feb 16, 2011 | 08:23 AM
erasmmuss's Avatar
You pull it is called, that service
Old Feb 16, 2011 | 12:21 PM
wtlee3's Avatar
Default oil cooler
This could be great news. Where is this oil cooler and o-ring? I thought I had a rear main leak but it doesn't puddle all of the time. $8 is worth a try!!!
Old Feb 17, 2011 | 06:14 AM
ubdevoid's Avatar
The oil filter is attached to the oil cooler. once you've removed your coolant tank reservoir you can see the cooler+ filter. Then once you've removed the oil filter then you can unscrew the o-ring.
in my car there was alot of oil under the engine, and it puddled up in pockets in the engine bay after a period of time then it will spill out onto the road.
I had at least 3 mechanics including my dad say to me it was a rear main seal leak. They were all wrong.
Before you buy a oil cooler pull out your old one, inspect it.
My oil cooler looked to have no oil on it when I changed the oil filter but once I pulled it out there was a diagonal spray of oil behind it which seaped down at the back of the engine and spread out under the engine so it was difficult to tell were the leak was coming from.
good luck.
Old Feb 17, 2011 | 06:25 AM
ubdevoid's Avatar
http://www.jollysupullit.com.au/Home/Home.asp
http://www.jollysupullit.com.au/ezip...%2007/95-04/97
Old Feb 17, 2011 | 08:34 AM
foxracing4500's Avatar
deleted
Old Feb 18, 2011 | 03:58 AM
  #18
ubdevoid's Avatar
Originally Posted by foxracing4500
not to thread hijack but what if you just connected the two coolant hoses together? Yes oil cooler would have no purpose but would it harm it?
Im a firm believer in the saying "It's there for a reason". Im no mechanic but im guessing without the oil cooler the oil would probably heat to an unacceptable temperature.
john s
Oct 19, 2014 05:17 AM
vtraudt
Jan 9, 2014 06:56 AM
hartze11
May 5, 2008 02:43 PM
a4BRZLowrider
Jan 2, 2007 07:49 AM
paradocs
Dec 30, 2003 01:17 PM
