wheel bearings?
Old Jul 11, 2008 | 08:41 PM
mhellman's Avatar
Member
Default wheel bearings?
I've got a loud humming noise coming from the rear of the vehicle. It starts at about 40mph and gets louder as the speed goes up. Because the noise doesn't start until such a high speed, I can't really swerve too much to determine if it's a left or right bearing issue. There is no noticeable noise at lower speeds. With a bearing issue, will there always be noise at low speeds? It doesn't seem to matter what gear it's in, or if the clutch is pushed down. I've heard that the tires might cause this too, although there was no noise when I first bought the car a few months ago. Any idea what else might cause this?
Old Jul 11, 2008 | 10:32 PM
vrooomaudi's Avatar
Default RE: wheel bearings?
I had the same problem and replaced my right bearing. Then in a few weeks had to replace the left one tooo.....IMO its the wheel bearings
Old Jul 12, 2008 | 02:28 AM
MrFlippant's Avatar
Yeah that's definitely a wheel bearing. I would go ahead and just replace both rear bearings; mine went out within a couple weeks of each other as well. Might as well get them both done at once!
Old Jul 12, 2008 | 03:46 AM
96A4Owner's Avatar
i had the same problem, dont drive the car your bearing is probably blown apart already. you dont want to make it worse.
Old Jul 12, 2008 | 03:12 PM
shady927's Avatar
what exactly would happen if your wheel bearings were shot and u didn't fix them? I know my drivers front wheel bearing is shot but I cannot spend ANY money until early september.
Old Jul 16, 2008 | 09:27 PM
mhellman's Avatar
Member
Thanks all for your responses.
Thrices_own
May 1, 2013 10:18 AM
mcarpen89
Jul 8, 2009 11:31 AM
mcgoey
May 9, 2007 08:31 PM
ShaodwMav
Jul 12, 2006 10:05 PM
Jacek
Feb 23, 2005 12:14 PM
