Wheel bearings
This isn't what i'd call a DIY job, those have to be pressed out of the hub. If your friend can do that, then more power to him, though he may be thinking of slapping on a bolt on hub assembly.
But, installation notwithstanding, It's probably better to grab the parts from your local Napa, who will stock SKF or another reputable brand, just to make it easier if you get the wrong one.
You could also pull your hubs and take em over to a Napa/mechanic and have em press the bearing for you.
This is your best bet. I had my ENTIRE front end pulled form the car to address multiple suspension issues.....I figured is might as well do the bearings as well. If I didn't have the whole knuckle out from the car I probably would have killed myself. Even using proper tools, we destroyed a shop press. Just to give you some perspective.
The press wasn't a "heavy duty" press but a shop press none-the-less. The bearings were stubborn as ****......we kept working it and then it happened....it was loud and scary.....my buddy was not happy. I have since purchased a new press for said friend.
I have a 20 ton press, looks like it was built out of railroad tracks. I've done a thousand bearings like this, but the stuck ones are still scary, once you get some pressure going, the energy stored in that thing is immense.
Still, not as frightening as the strut press letting go of the spring suddenly. The joys of using equipment older than you are!
