Wheelspeed sensor.
So, I'm sure a lot of you read about my idiocy and breaking my upright/wheelspeed sensor. The sensor would read 1 KPH all the time in vagcom, so - I went to the junkyard, got another sensor...issue is, this sensor had a cut in the wire, so I spliced it and taped it.
Still reading 1 KPH no matter what. My question is : Can these wires be spliced? Or is it a huge no no, and two : Is it at all possible that I screwed up the axle some how? Since isn't that how it reads wheelspeed? some magnetic marking on the area near the spline?
*edit* The new sensor, of course could be bad too. That would just be bizaar luck, though.
Splicing should be fine, the sensor is based on pulse and voltage variation I think and not resistance. It isnt likely the axle got messed up, you would probably have a reading that varied, but that was still different from the other wheels if that were the case. You might try pushing it in a little further, that was my problem (depending on what year, they had screws to hold them later I think).
Hey guys, went to the junkyard and grabbed a new tone ring. All is well, abs in full function even with my double splicing. I do need to get a proper wheelspeed sensor, as im sure the splice will eventually wear. Or re-splice it the proper way, depends on if i'm lazy or not
jkjersey
B7 Models
Jun 17, 2013 09:31 AM
audiblaze
Dec 11, 2011 02:08 AM
beholder
Jun 1, 2010 08:00 PM
neomaxddr
Apr 1, 2009 03:16 AM
TTsteve
May 7, 2006 12:34 AM
